is there an OTG function in BRAX3? as unable to find anything on the forum to help in this.
as want to use USB device but comes up with swith on OTG function.
any ideas?
thanks
Yes the function is already there nothing to enable just plug in a usb c stick and off you go transfer files backwards/forwards using the files app.
The only question I am asked was wrt formatting the plugged in device cos I accidentally put a ext4 formatted one in.
thanks for a quick response, I tried that, it comes back as turn on the OTG FUNCTION.
Have you checked all your USB settings? There are other threads on the subject…
Have you tried selecting ‘File Transfer’ for USB connection - assuming thats what you are trying to do?
not all but will do so, thanks
