How do I access MicroG settings? I’ve searched under settings and under the app search. Might I have deleted it by mistake?
Thanks.
Settings > System > microG Settings [it’s right down the bottom of that page]
Check if you’ve accidentally deleted anything:
Settings > Apps > See all nn apps -
… go to the three dots top right > check Show system > scroll down to m…
You should have:
microG Companion, microG Services, microG Services Framework Proxy
Of course whether these are the right version is a whole nother conundrum …
