@plamen how secure is a Brax3 against a law enforcement Cellebrite hack ? Is there any information in regards to cellebrite and the Brax3
The BraX3 is not tested against cellebrite devices. The device is designed to ensure user privacy by removing big tech from the picture.
In terms of security and ability to withstand such attacks, it is on par with the standard android security implemented on consumer devices.
DeGoogled privacy type phones only mean ads and things like that are not tied to you. They really dont much of anything different from standard Android phones, except let you log in with no sign on on some things to avoid Google and other ad trackers.
Thanks I saw Robs YouTube post about this yesterday it explains this well
Removing software (in this case google and bloat) reduces the attack surface, which generally improves security. But you are generally correct.
