How to Add Emoji Dictionary to HeliBoard
I am assuming that Heliboard is installed as standard as all my keyboards on Fossify, Brave browser, etc., look the same. I want to add a dictionary primarily to Fossify Messages so that I can use the Heliboard emojis dictionary. These are the instructions that I see:
To add a dictionary file for emojis to HeliBoard, follow these steps:
  1. Download the emoji dictionary file (e.g., emoji_en.dict ) from the official repository, such as the aosp-dictionaries repository on Codeberg.
  2. Open HeliBoard and navigate to the Languages & Layouts settings.
  3. Select the language for which you want to add the emoji dictionary.
  4. Tap the + button next to the “Dictionary” section.
  5. Choose “Add dictionary from file” and browse to select the downloaded .dict file (e.g., emoji_en.dict ).
  6. The dictionary will be added, and you should now receive emoji suggestions as you type, providing a functionality similar to “emoji search”.
Question: where is the Heliboard app stored or how do I access it?
Solution provided by laneb (thank you) on the IODE community board:
Open Heliboard, long press the comma button, (right to the ?123 button bottom left) a popup appears, select the gear symbol and then you are in the settings
You can also hold down the enter key (highlighted arrow key on bottom right on keyboard) which will give you a small popup for emojis and clipboard.
