Recently, last couple of months, about one time in 10 when I wake up my Brax 3 with Iode 7.1, the home screen launcher will not populate, blank screen with blurred desktop and no icons appear. When I tap a navigation banner icon I get an error something like App not available, not exact wording. I was hoping the update to 7.2, dated 1/31/2026, would fix the problem, but I can’t download the update. The error says to check my internet, which is fine for all other apps. This happens on cellular and WiFi. I kept trying for a couple of days in case it might fix itself, but it has not. I also cannot find the 7.2 ota release from the git site in the URL from the Iode updater. I am including the link directly copied from the Iode updater below. Best case the updater pushed the release to my phone too soon. Worst case, this is some kind of fishing URL. Be careful “https://gitlab.iode.tech/ota/release/-/raw/master/brax3/iode-7.2-20260131-brax3-ota.zip”
The 7.2 update was pulled immediately and is currently back for download 7.2 update is almost here
Just started downloading 7.2
Thanks, I need to find my way around a bit better. I looked for such a topic, but did not find it.
I installed 7.2. Fingers crossed is solves my launcher update problem.
