IodeOS WiFi connection issues - Eduroam
Hi all,
I cannot connect to the Eduroam network on IodeOS 6.9 (after the WiFi fix)
The network details:
WPA/WPA2/WPA3-Enterprise
EAP method: PEAP
Phase-2 authentication: MSCHAPV2
CA certificate: Trust on First Use (no certificate)
The username on Eduroam has format (similar to email) that looks like @uni.edu ( e.g [email protected] )
I get the responce “authentication problem”.
I can connect to Eduroam on LunarOS,
I also can connect on iodeOS 6.9 to a local network that uses the same setting (and probably provided by the same router) with only difference that username is just (without @uni.edu at the end)
I guess the bug has something to do with how usernames with @ or dots are treated on IodeOS.
Thanks in advance to anyone who tries to fix this.
Can you share which 6.9 version of iode you are running exactly. A hotfix for 6.9 was introduced that fixes the wifi connectivity issues.
I am now with LunarOS, but It was iode-6.9-20251116 , I updated to 6.9 after the wifi hotfix was introduced.
Thank you for confirming. I will escalate this to the iode dev team.
