KDE Connect and Brax3
I am very happy with my Brax3 but I am having problems trying to use KDE Connect. Anybody had the same problem?
Thanks,
Would you mind sharing what the problem is?
I am not able to use KDE Connect with Brax3, I might be doing something wrong. I don’t know.
You may want to read and properly follow the instructions: KDEConnect - KDE UserBase Wiki
KDE Connect is working good between my Brax 3 and my Linux Mint laptop
I found that my vpn was keeping my phone from showing up, once I turned it off things worked perfectly fine. Hope that helps
