I’d like to clarify the LED notification status
I lean to say Brax3 lacks the LED notificaion, correct?
I have checked the specification on
Plus did a few experiments with the phone itself and looks like the LED notification is missing, correct?
I haven’t noticed it. It would be nice. But I’m okay without it. My Pixel 8 didn’t have it, but I see up the flashlight to flash. Not ideal, but I works. Iodé also has flash notification. I just enabled it.
But if i’m correct flash notification works only during the phone ringing? While i’m looking for a notification after the e.g. a missed ringing/phone call. Correct?
Could you provide more info how did you enable it?
Search in Settings for flash notifications. It is limited and probably won’t do all that you’d like.
Thank you for the help. I just mention to others coming here, that flash notification is something different.
Led notification let you know that something happend on you phone.
Flash notification let you know that someone is calling you and phone is ringing (this is for situation when audio can’t be heared)
Anyway, thanks for clarification. ![]()
