Linux waydroid question
So I am thinking this and want to know if I’m right.
So on Linux mobile you have waydroid or a fork of.
So I am assuming when running any android app in that container those apps can only see data in the shared folders between main os and android correct ?
Also do those apps have access to info beyond the android system (usually lineage), like can they see main os, imei, etc.
If running a VPN on Linux side will that also apply to the android side or do you need to run a android VPN too ?
Thanks no advance.
