MintMobile APN settings and there's no data for the connected device. Or hot spot on BraX3
There is no place for , MVNO type: Gid , MVNO value: 756D ,on BraX3 The same sim card works just fine on my Pixil 6a .
Thank You Fred
[email protected]
Yes I have edited cleared used my pixel 6a APN settings, did not work.
Do you mean the following ?
Have you set up everything else?
This could be an automatic setting.
Try to remove the APN and add it again.
APN Settings
    Name – Mint
    APN – Wholesale
    Proxy – (leave blank)
    Port – (leave blank)
    Username – (leave blank)
    Password – (leave blank)
    Server – (leave blank)
    MMSC – http://wholesale.mmsmvno.com/mms/wapenc
    Multimedia Message Proxy – (leave blank)
    Multimedia Message Port – 8080
    MCC – (do not change default values)
    MNC – (do not change default values)
    Authentication Type – (leave blank)
    APN Type – default,supl,mms,ia
    APN Protocol – IPv4/IPv6
    APN Roaming Protocol – IPv4/IPv6
    MVNO type: GID
    MVNO value: 756D
I’d suggest you contact Mint support and ask if they see any issue on their end.
No hotspot and very low data usage (41 MB in a month) on my Brax3 either. Mint’s advice didn’t help. APN resetting hasn’t changed the situation. Thanks for asking about this Fred and thanks for the settings list George.
You can ask them to send you the settings in some SMS or some format that is loaded in the modem automatically.
That’s what they should do but they just send an SMS with a link. If u have no internet on your phone then u cannot see that link! Setup the APN on that phone while connected to wifi!
with or with out sim card I can get on the internet with wifi or hot spot. No cell data needs MVNO type: GID and MVNO value: 756D on Mint-mobile aka T mobile . MVNO is not available for Brax3. Mobile Virtual Network Operator
The modem should be able to configure those 2 fields, there is a binary file with .mbn extension that is used to configure the carrier and it is downloaded automatically when you connect to the network, they should be able to push it to your phone.
Check this one, Reddit - The heart of the internet
