Swisscom SIM (local):
IMS Registration: Registered
VoLTE: Available
Calls work fine
Fastweb SIM (roaming):
IMS Registration: Not Registered
VoLTE: Unavailable
Incoming calls → busy tone
Outgoing calls → no audio, call drops after \~10 seconds
Cross-test
Same Fastweb SIM works perfectly (VoLTE OK) on a Samsung phone in Switzerland
Interpretation
Hardware supports VoLTE (confirmed with Swisscom)
Fastweb network/SIM is OK
Issue seems related to missing or incomplete carrier config / IMS provisioning for Fastweb on iodéOS, especially in roaming
Questions
Is Fastweb (or similar MVNOs) supported for VoLTE on Brax3?
Are there plans to expand carrier configs?
Is there any way to manually add IMS/carrier profiles?
Seems like an APN misconfiguration. If you can find the APN settings for Fastweb on the internet, try setting it up and checking if it will fix the issue.
If you can’t find APN settings, or reconfiguring the APN settings didn’t fix the issue, I would highly recommend to reach out to the carrier directly and ask if they see any issue on their end. They should be able to access logs that gives them the full picture - APN misconfiguration, failed tower connections (if bands are missing), or else.
Not much to do on your end other than making sure the right APN is set.
I’d recommend reaching out to the carrier to see if they can identify any issue from the logs.
