OLED PWM frequency?
When it comes to OLEDs, I find I can’t look at them for more than a few minutes if the PWM frequency is low. What will the frequency be for the Wink’s OLED?
Adding my voice here, since this is the one thing that decides whether I can use the Wink. I’m PWM-sensitive too and put my deposit down on day one. The same question was asked in the “hardware-level display specifications” thread and hasn’t been answered there either, so there are at least three of us asking about this.
Since the specs aren’t finalized yet, this seems like the right time to ask:
  1. Can you share the PWM frequency and the brightness range it applies to, or the target if the panel isn’t chosen yet? Some of us can tolerate high-frequency PWM, so the actual numbers matter.
  2. Is a DC-dimming or flicker-reduction mode possible, either at launch or in a later software update?
  3. Request more then question. Can PWM behavior be weighed when choosing the final panel? A high-frequency or DC-dimmed OLED would make this usable for us, even at extra cost.
  4. Will the display be replaceable, with the connector and panel specs documented, so an aftermarket swap is possible later?
I raised the same concern for the open_slate’s OLED.
Low-flicker devices are few and far between, so any detail helps.
