I did not have any problems with the new
iode upgrade to 6.7
All seems to work
Richard
iode upgrade to 6.7
All seems to work
Richard
Same here, all good on 2 phones with 6.7
ditto ![]()
…i have to write 20 characters…
I’m looking for the change log.
there is a grey “io” icon that shows the iode news, tap it to view the changes
@richard @krog @Mycenius Just to clarify, you are saying that you did not see any new problems with v6.7, right? As in, the wifi issues mentioned in the following post still persist, correct? At least, that is what I am assuming. I suppose many people will not want to go through the trouble of upgrading until that issue has definitely been resolved.
I did not have any problems with my wifi at all
So i can not give more info about that
There is no reference to the WiFi in the update changelog, you can skip it in that respect
Ditto on that @inverdell - I have no issues with wi-fi as I use dedicated Ubiquiti Uni-Fi WAPs and all works okay. I’m also still configuring my phone so not using it as my daily driver (still using iPhone) - so my usage currently is mostly just installing apps, setting up and testing them, and configuring settings and utilities… (and haven’t installed either of my SIMs yet).
