Privacy Screen Protector
I have found the perfect size privacy screen protector that will fit from the front camera all the way down to the bottom of the screen. this is my Phone in the photo.
Thank you for this information. I was looking for one that will Fit my phone. The one I ordered to brax barely fit.
Thanks for that - it’s good to see a different model of phone that has the same screen dimensions. It opens up some options.
I like the hydrogel type screen protectors - I have to replace them about once a year but they don’t break if damaged…maybe now I’ll be able to find some for the Brax3
Ahh very nice find, thank you.
Hi does anyone know if a Revvl 7 or Revvl 7 Pro flip case would fit the phone? Has anyone tried this or any other flip case? Thanks
The camera holes won’t line up, but I am not sure on the overall dimensions to tell if it might be modified to fit
So did you look into an otter box case that will fit the brax3 as every one is waiting :slight_smile:
