Ring and Email Tone not working
What is “VoIP.ms”? The native app is Fossify Phone.
it is another voip app that allows text messages too.
Interesting, when I try to send a text thru fossify, I get a “not sent. Touch to retry.
You have some complicated setup so maybe there is some conflict between the apps. Anyway trying different apps solves the problems in many cases because it seems to be some problems with the Fossify native apps.
Okay, very good. I will keep trying.
QKSMS and some other phone app usually wakes up the Fossify apps and then they work properly.
Hi george!
Thank you for that. I may need that. Anyway, with one test call coming in the phone rings with a change in the password per tech support at Brax.me. Thanks again.
