Signal app help
Another issue I need help with…
On my brax 2, the Signal app worked without issue.
On my brax3 I don’t get my messages right away.
I seems I have to have the app open and upfront to get my messages.
I don’t know what setting to fix…
…and I have been in and out of the settings menu trying to figure out what the trouble is.
Has anyone else found this to be the case?
Can anyone help me get Signal back to reliable?
Check the following: Apps → Signal ->scroll down and look to see if in “Advanced” there is an option to “Display over other apps”. If there is, try enabling this function.
I don’t have signal, but I had to do that for Sipnetic to get it to stay active and receive phone calls.
I’ll look into that. Thank you.
You probably shouldn’t use Signal if you’re worried about privacy.
I must ask, why not?
Why not use Signal message
I’m having the same problem with Signal. There does not seem to be an option to “Display over other apps” for Signal. Has anyone solved this problem?
