Sleepy Ethernet on Brax3
I’ve been meaning to put out a post for this issue for a couple weeks now: I have switched to using Ethernet exclusively for my Brax3 when not on the go. I’ve noticed that when I lock it/turn the screen off when not using it, Brax3 has dropped the Ethernet connection and has to re-establish it once I wake & unlock it. (Reconnection usually has taken any where from 5 to 15 seconds.)
I’m particularly concerned about it because of the underlying logic. Why would something that is hardwire-connected disconnect, whereas WiFi is not interrupted at all? It also means that I am unable to get alerts for potential emergency/high-priority situations if they arise.
The issue has persisted with Airplane mode on and off.
As reference, I tried the same Ethernet connection experiment on an iPhone. While certain activities (e.g. receiving calls) do not wake the iPhone when Airplane mode is enabled, they DO wake it when Airplane mode is off and the iPhone is connected to Ethernet (Cellular, and WiFi are both turned off from inside the System Settings App when I’ve done my tests).
I’d appreciate some insight (and hopefully a solution) from anyone (including the development team) who may know what’s going on. It makes sense that since Brax3 was made to be a Privacy phone (Ethernet with the appropriate VPN & network configuration is arguably more “private” than WiFI…. since every WiFi network is apparently visible on a public list.)
The below video is what supports my statement about Ethernet vs WiFi:
Naomi Brockwell: Snowden Says Not to Use WiFi (Pubic record of all WiFi networks that are created by the devices manufactured. Connecting via WiFi exposes Mac Address. Tether and use ethernet instead)
It may be protection from that tool that connects to the USB and brute forces the screen lock or some other related security reason, for example I think the debugging mode stops when the phone locks.
Remove the lock to see if it’s related but it may be deactivated anyway when you turn off the screen. Generally Android blocks many things when the screen is off like camera capturing.
They talk about it in this very old post, [SOLVED] Keeping Ethernet active when screen is off/locked | XDA Forums
I don’t know what’s the current state, he tweaked the Linux filesystem directly.
Android by default spoofs the WiFi MAC address, you have to turn it off in the settings.
Thank you for sharing the feedback. Can you share which OS version are you currently on, so we try to reproduce this in the same environment?
Hi Plamen, it is Android 15 and iode 6.3-20250526-brax3
Upgrade to 7.2
Activate caffeine in the toolbar (add it) so the phone doesn’t go to sleep and then dim the screen.
I never had any ethernet issue with any other android before. I’m having now with brax3. Contacted the brax support, they told me to ask for help here. Ethernet connection is completely random, most of the time it does not work at all, the cable is live and working fine with PC and other android phones. Sometimes a get a connection for about 20min or so. My USB hub with the RJ45 ethernet has a led light to show it is connected, most of the times, when I connect to the Brax3 that light give some quick blinks and then stays off. I was thinking a faulty usb socket on the phone, but it charges normally and connects to the PC with no issues… so I guess it is some configuration or bug on the OS… no clue
