Spare protection sceen
How and where to order a spare tempered glass protection screen ?
after 6 months use, it is now damaged and scratched…
Have you removed the plastic cover? The glass can only be scratched by another glass of similar or greater hardness, not even sand in your pocket can scratch it.
Plastic cover removed long time ago… Recently, there was indeed a fall of 1 meter, flat onto tile flooring, and the cracks on the side spread. Fortunately, it is indeed the protective cover and not the screen.
You meant you scratched the protector. You can use one of similar dimension and I believe a larger one can be reshaped with a glass cutter if you do it carefully.
I gleaned these from previous posts. Have not needed to use any. Check them out…
For Brax3 look for 6.57" screen protectors
SuperShields TG005428 Tempered Glass for T-Mobile REVVL 7 5G these are clear.
3 Pack Privacy Screen Protector Designed for T-Mobile Revvl 7 5G,Full Coverage Anti-Spy Tempered Glass Film,9H Hardness,Anti-Fingerprint,Bubble Free,Easy to Install
Brax3 Screen Protector:
- Nokia G310 5G clear screen protector
- A Redmi 13C case (and screen protector)
- Beukei 9H Tempered Glass Screen Protector for Xiaomi Redmi 13C
https://www.amazon.com/dp/B0F28ZRZKJ?ref_=pe_148126100_1193965070_t_fed_asin_title
Thanks to both of you.
-Mobile Revvl 7 5G is not available in Europe : I found a protection screen for Samsung A17 which perfectly suit : MAYtobe 2 x Anti-Spy Tempered Glass Screen Protectors for Samsung Galaxy A17, Privacy Screen Protector, Bubble-Free, 9H Hardness, Anti-Scratch
real dim : 7,2 x 15,9 mm
Amazon.fr
“This project doesn’t allow to pledge add-ons only.” If it weren’t for this rule we’d be able to buy accessories am I right?
there is the store at brax.me, maybe you can buy from there
no george.
it’s just a smartphone, buy something that fits, Plamen has even uploaded a 3D-print file for the case
