Is the supplied usb cable a data cable or just a charging cable?
I’ve used it to transfer files to and from my Windows PC just fine.
Note that by default the Brax is in “charging only” mode when you plug it in (which I really appreciate, really). You need to go into the notification that it’s connected via USB to put the connection in File Transfer mode.
