I am somewhat new to the networking side of things.
I have a nas setup to remote into with tailscale, I use it for jellyfin and immich.
and I use bytzvpn.
On my Brax3 I can not see a way to use tailscale and openvpn, it tries to activate both and says only one can be used at a time.
On my furiphone I am able to activate tailscale in terminal and use openvpn through network settings. Problem is openvpn kills my battery life and bytzvpn does not have a wiregaurd option.
Is there a way to use both on android that I am missing ?
Yeah I have checked on the furiphone. It uses them simultaneously like any of my other Linux devices. But yeah android was always shutdown the other, I am able to have one or the other active.
I thought you wanted to tunnel Tailscale through BytezVPN. Android is very strict with security, if you could do that probably any app would be able to circumvent your VPN.
