i just opened my brax 3. yes, it took awhile to face it!! it says the os is 6.3 and needs to update to 7.1- but then it says the update is blocked and cannot be installed using the updater app. then has a link to go to- i go to link and it says page not found. please help! i am a newbie with this os. thanks all you awesome people.
Hey there.
To upgrade to iode 7.x version, you will need to first update your Updater app, as per this announcement: iodéOS 7 is Now Officially Available! - iodé
Link for the updater APK: https://gitlab.iode.tech/ota/ota/-/blob/master/fixes/Updater-v6-to-v7.apk (might be easiest to download on your PC and transfer it to your BraX3 via USB).
Once you update your Updater, you should be able to download and install iode 7.1
If the download gives you an error, you can download the build manually from here: brax3/iode-7.1-20251227-brax3-ota.zip · master · ota / release · GitLab . Once the file is transfered to your phone, you can use the Local Update feature of the updater (top right corner when you open the app).
Why don’t you download it directly from the phone ? The browser will save it in the Downloads folder.
After selecting “local install” and wondering for several minutes why nothing was happening at “0%”, restarted the phone, then received a popup at bottom of the screen “could not update, are you connected to the internet?” I ignored that and proceeded to the updater which displays “iodé 7.1”.
About phone reveals that 7.1 has indeed been installed. Confirmed “iodéOS version 7.1-20251227-brax3” as well confirmed Android version 16.
Thank you.
I had done this once, I don’t remember how it goes.
