USB Lack of connection to PC with iodeOS 7.0
Continuing the discussion from USB connection to computer:
Did not have any difficulties in all previous versions of iodeOs 6.xx.
The Screenshot is with my Brax3 Phone plugged into my USB port on my PC.
I am trying to download many photos to my PC from the phone.
As you can see all the buttons are grayed out.
Is there another prerequisite setting to allow for file transfers?
Solved! :woozy_face:
Okay, all I had to do was change the USB Cable.
I found the cable that originally came with the Brax3.
It’s a much heavier cable.
Yes - i was going to say that looks almost certainly like a cheap or faulty cable issue!
Many low cost USB cables don’t have all pins connected, or they are poor connections. So no use for anything other than charging…
