Water Resistant?
I was not able to locate this topic, but is the Brax3 water resistant? Thank you.
There is no water resistance rating as it is designed to be easier to disassemble than the average phone which has a lot of seals and adhesives used in order to make it water resistant
Do you know if that means hardware upgrades could be done?
I don’t expect upgrades, just replaceable battery and other parts that may fail
…yeah, upgrades is more a Fairphone thing… (or in a related way Framework laptops).
Does anyone know of a waterproof case for the Brax3? Thanks..
