What's Next for Brax?
With ~200 units remaining in indicated inventory, will there be another production run?
Is a Brax4 under consideration?
What is the future? Timelines?
Thanks.
Would like to request a flip phone
Hi. I believe a tablet is in the works. Hopefully within the next 3-12 months? I think the plan is to do another indiegogo campaign, but I’m not sure. :wink:
I would definitely want a tablet when it’s available.
@plamen Any update on this?
there is a huge availability of simple phones on the market from 2G to 4G
Brax3’s motherboard should be very easy to migrate to a larger case with a larger screen, you can find such things on the internet and make it on your own
