I read awhile ago that if you skip an update it could brick your phone. I am currently on iodéOS 7.5 and the next option I see in my updater is 7.7. Would going to 7.7 be fine or do I need to install 7.6 first?
That’s what I want to know.
I would just update what is showing there. I am on 7.8 and don’t think you need to go manually find and install older updates just so you can install the most current one.
@plamen would skipping 7.6 be an issue?
I went from 7.3 to 7.7 and my phone is working.
I bought a Brax3 last summer. I updated it and it bricked. I returned it and they finally sent me a new one, but in the meantime I’d gone back to using my Pixel 5 with CalyxOS. When my replacement Brax3 arrived, I just kept using my Pixel since it was smaller.
My Pixel finally gave up the ghost, so I just opened up my new Brax3 and ported over all my apps and files. But I see I’m on iodeOS version 6.3-20250526-brax3.
Questions:
- Should I update my OS?
- If so, why?
- And how would I go about that? Are there intermediate steps I ought to take, or can I just jump to the latest?
- If 7.8 is the latest, would there be advantages to stopping at, say, 7.6 instead? I’m not the type of person who needs to be bleeding edge.
