Wireless projector display
Well I got my wireless Renkchip-EEA4 display adapter working on the BraX3. It is flaky…sometimes it doesn’t see it and sometimes it does. Reboot your phone if it won’t see the adapter. In phone settings type in cast and Google Cast and Google Cast again. Then enable wireless devices by tapping on the 3 dots in the right corner and make sure that box is enabled. Then u should see the Renkchip adapter as an option that u can connect to. Tap it and after about 5 seconds it shows up on the big screen!
It doesn’t show as an option on the BraX3 running Ubuntu Touch which I don’t get. I thought it might be a hardware issue in our phone but it does work in iode’! :face_with_raised_eyebrow:
The adapter has 2 modes-Android and iPhone. Place it in Android mode for iode’. Ubuntu Touch won’t see it in either mode!
I think UT needs a kernel module for Renkchip-EEA4!:face_with_raised_eyebrow:
The package used by UT 24.04 is aethercast. I tried to install this when the phone was writable and apt ran out of space on it’s partition. Hopefully this gets installed for the BraX3 on UT 1.0!:nerd_face:
