I am able to download Microsoft authenticator and intelligent hub but cannot launch my work portal ad it needs Google Play services. Is there any work around this i dont want to carry 2 phones .
If you have microG enabled, and you see this message, chances are that you won’t be able to use the service on your device.
Im not sure how to enable microG
Settings > System > MicroG Settings
Then see if in self-check you have all enabled (permission to appear on top of other apps isn’t needed).
See if you have device registration on, giigke safetynet, same for settings inside Play Store services.
