7.6 0701 spflash?
@plamen @vincent can we get the spflash zip for the latest 0701 release? And why does it seem to frequently go forgotten when posting a new release?
Cf also this thread:
FWIW I spflashed the 0623 release and haven’t had any issues as far as I’m aware.
@tech-support can we get an spflash so I can install the fixed build? And can you make sure it gets posted every time?
Frustrating that no one from Braxtech/Iode responds to this issue, and hasn’t to similar past posting issues, especially since I have no way to move off of the original damaged 7.6 build. @plamen @vincent @tech-support
Agreed! U forgot one:
@braxtechnologies
Apologies for the hold up on this. We’ve escalated this to the devs. Will report back
We’ve uploaded a new spflash build. Tested and working. Let us know if you still have any issues.
Link: Brax Technologies Downloads Platform
I bookmarked the page-thank you!! :clap:
I got that one and appreciate it! But I see 7.7 is out now and there’s no spflash zip. Can you get this resolved @tech-support and can you ensure the release process is updated to include it?
And interestingly, it looks like the 7.6 spflash zip got deleted from the 7.6 directory! What is it about the spflash zip??? It’s like someone doesn’t want them shared or something. :frowning:
Yes, we’ve deleted the spflash files, until we can figure out and fix the issue causing bricking devices from the new batch. Work is still in progress, once fixed we will reupload again.
In the meantime, if you’re looking to make a local update, iode updater local update is your way to go (using the ota file)
Fortunately the spflash did show up in the list of files so I have it now (not yet installed). Hopefully it’ll be consistently posted from now on. Thank you!
We’ve added the spflash build for v7.7: https://download.os-source.co/brax3/iodeos/v7/7.7/
Tested on both versions of the BraX3 hardware.
I finally got a “download OK” message with using SP Flash on iode’ for the 2025 phone! :nerd_face:
