Has anyone experienced issues when charging above 90 % with wire the phone keeps connecting and disconnecting from charger and does not go full to 100 percent, if switching to any charger block 65 watt and above will charge normally why is this the case?
Any updates on formatting the speakers for clear crisp sound because they are fuzzy especially at higher volumes or is this a design flaw due to pricing?
Also is Yubikey compatible with Brax 3 and would it fall under NFC for password and lock because hardware or security key does not seem to be a option?
If there is any F-droid apps that could help with this or any apps you recommend in general to download for better use and cool features would be appreciated.
Yes still occurs with it disabled but before then never set up alarms so it shouldn’t have synced anyway based off alarm times, but gets worse when it is above 95 percent and can confirm by hearing sound and vibration of disconnection. Using OEM wire with extender and even took it off the usb extender and same issue persist.
Is this issue only occurring after 90% charge?
Does it always have the issue after 90th percent and never has the issue under before 90th percent?
This isn’t really a hardware design flaw. It seems that BraX3 running iodeOS exhibits speaker issues, most noticable at higher volume. We’ve tested the stock OS (LunarOS) and the speaker sound is much smoother. The quality won’t beat an iPhone, but it’s really close to Pixel (I randomly tested it with a couple of musicians which mentioned they don’t notice a difference between BraX3 and Pixel 7).
We have a lot of cool community-generated articles in this forum. I plan on putting together a single topic that links to high-value how-to/guide articles from our community members.
This is great one to start with: 0x7 Brax Guide/Hype
