Does the Brax3 support wireless charging?
Not by default - you need to use an adapter that plugs into the USB-C Port - the type that is flat like a credit card and you lie it under the back of the phone when you put the phone into the case.
A search of the forum will find you this thread:
Thank you very much! I should have thought to search for it haha
