BRAXSim Unlisted BRAX3 MMS issue - FIXED
I was having a frustrating time trying to adjust my ANS settings again and again to get my MMS working. I tried the fix that worked for everybody and it wouldn’t work. I used every trick I could find on the internet. Then I gave up and contacted BRAXSim directly. They responded this morning with a new ANS to try. It worked immediately. I’m so relieved. FYI I ported from Verizon. Details below.
APN: Wholesale
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS Proxy: Not set
MMS Port: Not set
MCC: 310
MNC: 260
Authentication Type: Not set or None
APN Type: default,supl,mms
APN Protocol: IPv4/IPv6
APN Roaming Protocol: IPv4/IPv6
Bearer: Unspecified
MVNO type: None
I hope this helps anyone in the same situation I was. Cheers!
Hey, just found out about BraxSim…@kdicksando did you (perchance) use a gift card when you opened your account?
