HotSpot can not be turn on (is gray option only)
My Brax3 phone in the past allowed the usage of the HotSpot, last week the option to turn HotSpot on/off is not active it is grey. I was looking in the settings and did not find the solution. have any of you ideas what is the problem?
Kind rgards.
Hey there.
What version is your OS on? If not on the latest (7.9), make sure to update it.
Check the software section in the FAQ page if you encounter any issues while updating: BraX3 Frequent Questions and Troubleshooting.
