I never had my Sim card in my second BraX3 when it was running iode’. Maybe the Sim card reader is bad-I doubt it since I’m not the only one with a BraX3 who had problems with the Sim card using Ubuntu Touch, but if it works than Android would detect it.
When you get a new device you should test every function and especially the modem and the WiFi/BT, for example LineageOS emphasises this in the instructions, you have to be sure that the phone was already in a working condition before deGoogling.
For SPFlash the appropriate file is the *spflash.zip (brax3/iode-7.2-20260131-brax3-spflash.zip · master · ota / release · GitLab), inside that there is an XML file in the download_agent folder that is loaded to the tool describing the partitions. The *spflash.zip contains all the appropriate partitions as .img files, maybe the recovery has to be flashed separately but you will see that in the instructions.
I have SPFlash for Linux extracted at / of Linux Mint. The included script with sudo from terminal starts the GUI. Maybe it has a spot for the iodé recovery file with the iodê SPFlash file?
I wasn’t concerned about that Sim radio not working till now. I’m not a phone person but I’m testing Ubuntu touch for those who are!
Well, I got back to iode’ using SPFlash in Linux…but I’m missing something which I noted down. 2 things, I think-both IMEIs are gone as it wanted to flash the firmware. I have the SN Writer but it is for Windows. Is there a Linux version of this?
Also, I didn’t have to flash the recovery file. That is included in the SPFlash iode’ file.
The IMEIs are on the box. There is no Linux version as far as I know. It could be able to run through WineHQ if the compatibility layer can communicate properly with the USB driver. I can’t know whether trying this could somehow brick the phone.
I imagine that Lunar has no functional difference from iodé, only the updates are done manually, don’t expect anything soon, it would be already available. Use the @ tag to notify plamen.
That rooting method with Magisk doesn’t seem to work anymore.
I am only able to install Android on my BraX3 right now. I tried again 2 more times to put Ubuntu Touch on it and I keep getting boot loops. Maybe UT won’t install when IMEIs are missing?
Right now I have unrooted Lunar OS installed. I have an old laptop with Windows from 10 years ago that might run that SN Writer software. I’m thinking that OS is too old to do much anymore!
We don’t have any Linux compatible tools for flashing IMEI or S/N unfortunately. We’ve been asking for quite some time now, but still didn’t get one from MediaTek.
You can’t preserve user data when switching between different OS. That’s only possible if you are updating to a new version of the OS.
I strongly recommend also choosing the firmware update option as well with spflash when switching between different OS. Firmware update doesn’t allow userdata preserving.
