iodeOS wifi connection issues
@rik also grep -ril "handshake"
1467/p2p_supplicant.c
1467/wpa_supplicant.c
1467/todo.txt
1467/events.c
1467/config.h
1467/README
1467/doc/docbook/wpa_background.sgml
1467/doc/docbook/wpa_priv.sgml
1467/doc/docbook/wpa_supplicant.sgml
1467/ibss_rsn.c
1467/wpa_gui-qt4/wpagui.cpp
1467/wpa_gui-qt4/lang/wpa_gui_de.ts
1467/sme.c
1467/ChangeLog
1467/dpp_supplicant.c
1467/wpas_glue.c
1467/ctrl_iface.c
1514/config_ssid.h
1514/scan.c
1514/p2p_supplicant.c
1514/wpa_supplicant.c
1514/todo.txt
1514/events.c
1514/config.h
1514/README
1514/doc/docbook/wpa_background.sgml
1514/doc/docbook/wpa_priv.sgml
1514/doc/docbook/wpa_supplicant.sgml
1514/ibss_rsn.c
1514/wpa_gui-qt4/wpagui.cpp
1514/wpa_gui-qt4/lang/wpa_gui_de.ts
1514/sme.c
1514/ChangeLog
1514/dpp_supplicant.c
1514/wpas_glue.c
I can report that the BRAX3 effortlessly connected to my VERIZON home Wi-Fi
Hi, just downloaded the latest iodeOS v6.7, rebooted twice and no success connecting to my Asus AC-2900 RT-AC86U with the latest firmware. Both 2.4 & 5G give back the same old response to check password and try again. One thing I did notice this time is the it acutally took a sec or two to scan and return the failure notice. Phone will connect to both home frequencies networks when I place them in Open. Hope this helps. Thanks for the effort.
So the Pixel 9a that I purchased on discount from my ISP arrived today. It’s SKU GA05769-US which Best Buy also sells as an unlocked phone. As far as I can tell this is indeed non-carrier locked hardware. There is no mention of my MVNO, or T-Mobile (who sells them tower access for my mobile plan), anywhere in the phone settings, and no carrier-specific apps installed, etc. Just straight Google ROM and apps…
Anyway, this phone shipped with Android 15 and I had no problem connecting to my currently deployed ASUS RT-AC68P Router - the same router that my BraX3 cannot connect to. I also allowed this phone to download a 1.3GB OTA update to Android 16 and it still has no problem connecting to my ASUS RT-AC68P Router.
Just another data point to ponder (not trying to sell Google phones here… :^)
… I successfully unlocked the bootloader on this Pixel 9a. No LineageOS ROM available (yet?) and CalyxOS has temporarily withdrawn their ROM images. GrapheneOS supports this model and I used their web installer to download and install their latest ROM. This is also Android 16 and it also successfully connects to my ASUS RT-AC68P Router (which my BraX3 cannot connect to).
Again, not promoting Google phones here, just providing another data point…
Still hoping to eventually see the BraX3 fully supported on Wi-Fi 5 / 802.11ac routers!
you fell into the trap, Android 15 was the last version for Pixels with open source Linux and this is why Calyx stopped, now only the Android Framework is open source and I think you can’t go back to Android 15, LineageOS will continue with closed-source Linux, but you should check the website, I remember there was no 9a support
did you notice what revision the Androird 15 was ?
it should be something like Android 15 r14
By “trap” I assume you mean Google no longer providing device trees and driver binaries with their AOSP source? Yeah that’s gonna be a problem going forward for third-party developers. Not sure how long those devs will be able to hold out on earlier Android versions…
LineageOS has no Pixel 9a images available.
CalyxOS Downloads page has a link to a Pixel 9a image, however all of their download links have been redirected to a boilerplate message regarding the project basically being on hold, ostensibly due to two lead devs departing (but no explanation as to why they left).
No I didn’t pay attention to the build number on the original Android 15 that came on this Pixel 9a. I never even logged in with a Google account but it had already staged the update to Android 16. Oh well, “Onward and upward” as they say… :fireworks:
If the third-party Android ROM scene gets too convoluted then I can just get a flip phone for phone stuff. :smirking_face:
If anyone is using a Mikrotik AP with routerOS - try installing the latest RouterOS - and enable WPA3 for WiFi. Works here for mAP2nd, cAPXLac and RB962UiGS-5HacT2Hbt
Is there a Brax3 6.7 OTA? If so is there a link?
Anxious for a fix I guess.
It’s beta, you either download it and install it as a local update or you use the installer for betas.
Did side load the 6.7 beta file. No fix for actiontec router connection.
Sane here. 6.7 Beta still does not connect to my Mikrotik router.
Tried 6.7-20250823 Nokia router still not working
I have a NetGear Nighthawk AC2300 Smart WiFi Router Model R7000P that wouldn’t connect via WiFi. It will connect using CAT6 Ethernet cable and USB C to Ethernet Adapter, Driver Free RJ45 to USB C that I found on Amazon, here’s the link: Amazon.com. I’m not very tech minded so I found the easiest plug and play option. The WiFi connection issue still needs to be resolved, but this is a work around that might help.
We know that works this way, you can also make the WiFi open with MAC filtering to allow your devices only and turn off randomization of the MAC on Brax3 and use a VPN.
Arris Model: NVG443B WPA/WPA2 does not allow my Brax3 with latest Beta update 6.7-20250825-brax3 to connect. Saved/Check Password and try again error message
iodeOS 6.6
Netgear R7000
5GHz and 2.4GHz WPA/WPA2-Personal fails
F@ST 5366 TN
Google Pixel 7 hotspot
2.4GHz WPA3-Personal works
Entered the BraX3 MAC number directly into the Actiontec router GUI wireless MAC authentication location - manually enter MAC address. The Brax was denied.
WPA3 always works as far as we know
Turn off the MAC randomization in Brax3 and use the unique hardware MAC, also the MACs you enter in the router should be in the allowed list, not in the deny list.
