Hi Community,
This post is made to track the issues reported with WiFi (WPA2 protocol).
Both Brax Technologies and iode team will be posting updates on the progress in this page.
If you are facing issues with WiFi Connectivity on your BraX3 running iodeOS, you have one of the following options:
- Wait for a fix of iodeOS for the BraX3 to resolve the issue. No ETA available yet.
- Use a router that the device has been tested with and is working: iodeOS wifi connection issues
- Try to change the protocol from WPA2 to WPA3 on your current router
- Install LunarOS as an alternative Operating System, that works with all routers and protocol ( Welcome to LunarOS )
- Return your device for a refund
Update (November 18th '25)
A working fix has been deployed to all BraX3 deviecs. iodeOS version 6.9
Update (October 20th '25)
LineageOS is now booting on the BraX3. We’re in the process of testing the WiFi with in the environment reported where it’s not working. WiFi was tested and working with several routers already. I will post an update once we’ve done a proper QA on our end as well, testing on rotuers that are affected currently.
If the WiFi works on LineageOS, pushing a fix on iodeOS becomes trivial.
Update (October 16th '25)
I’m posting a new update regarding the wifi issue.
The issue is still not fixed on iodeOS.
We’re progressing with LineageOS port and expect to have a port done by early next week. The port will be in early stage, so it won’t be fully functional, but it will serve as the base for lineage devs to work on the wifi issues. As mentioned previously, once the issue gets fixed, iode devs will have an easy time applying the fix to their OS, considering they are forking lineage.
We’re very confident in the capabilities of the lineage OS devs. They have already done successful ports to MediaTek powered devices, including some of Nothing’s phones - which we share the solution house (dealing with low level drivers) supplier with.
Update (October 8th '25)
It’s hard to predict an ETA on a fix from iode.
There were a lot of positive signs last time I posted (e.g. making WPA2 working, but braking WPA3) but the issue is still not resolved.
We were hoping that involving devs on our end (more familiar with BSP development), will help resolve the issue quick. What ended up happening is getting iode broken (BSP developers aren’t familiar with iode/lineage code, and iode team isn’t familiar with BSP code).
We haven’t given up on resolving the issue. We are exploring different ways to resolve the issues, that are in our control, including:
1. Fixing the issue on iodeOS
We’ve contracted LineageOS developers to port LineageOS on the BraX3.
Lineage developers have way more experience resolving similar driver/HAL related issues - it’s what they deal with on every new port. When successful on the BraX3, it will be easier for iode team to port the changes to their OS and thus fix the issue (iodeOS is a fork of lineageOS after all).
We’ve been looking into porting LineageOS for a while, but the priority was not high, as it was just another OS option to introduce (similar to UB touch). Now the priority on LOS port is high, as it is expected to resolve issues with iodeOS.
2. Porting more operating systems to the BraX3
While 1 remains priority, we will add more OS options as well. We’ve already ported UB Touch (installable build will be shared very soon), working on LineageOS (as shared in point 1), working on CipherOS port. We’re also discussing making LunarOS more user-friendly as well, making it closer to stock OS experience, similar to what BraXOS was on the BraX2.
We still believe that collaborating with different custom ROMs is the way to go. We won’t give up on that. We’ve learnt a lot of things in this process so far, and understood that some mistakes were made. We will do what is in our control. The rest is noise.
With various combinations of wifi routers / APs not correctly authenticating using iodéOS, the below chart can help us better centrally track what makes / models / protocols are working correctly and what other devices are giving issues.
| Make / Model | WiFi WPA2 Status | Notes | iodé Version | Reporter |
| Actiontec GT784WN H/W/5A | GromPilot | |||
| Actiontec GT784WNV | Handy | |||
| Actiontec MI424WR-GEN2 Version F | 6.8 | |||
| Actiontec T2200H | 6.6 2025-08-03 | Greenie | ||
| Actiontec T3200M | Greenie | |||
| Amplifi Home Wi-Fi model AFi-HD | EdwardTeach | |||
| Arcadyan VRV951A (Swisscom) | raggadaz | |||
| Arris Group, INC Model G54 | abdullah | |||
| Arris NVG468MQ | DeeGu | |||
| Asus GT-AC5300 | WPA/2 | ProxyGeek | ||
| Asus RP-AC56 Wireless-AC1200 Dual-Band Access Point | Diode | |||
| Asus RT-AC1900P (has the latest firmware) | 6.6 2025-08-03 | blueduck | ||
| Asus RT-AC5300 | Diode | |||
| Asus RT-AC53U | TheCableGuy | |||
| Asus RT-AC66U | RogerZ | |||
| Asus RT-AC68P Wireless-AC1900 Router | PeterBX | |||
| Asus RT-AC68U w/ JRS Eco firmware 587.1_4 | 2.4/5GHz | 6.6 2025-08-03 | wardee | |
| Asus RT-AC86U | james119 | |||
| Asus RT-AX57 | krog | |||
| Asus RT-AX86U Pro AX5700 | PeterBX | |||
| Asus RT-AX88u model 2019uk | 6.8 | |||
| Asus RT-N12 | TheShanMan | |||
| Cudy WR3000H v1 with OpenWrt 24.10.2 | dobby | |||
| D-Link DIR 868-L | MichaelA | |||
| D-Link DWR-978/E | Robcwm | |||
| DD-WRT (not sure models) | bejinxed | |||
| DD-WRT - Linksys e1200 | 2.4/5 GHz | 6.6 2025-08-03 | 3n1gma | |
| DD-WRT v3.0-r48296 (Netgear R6400v1) | TheShanMan | |||
| DD-WRT v3.0-r58124 (Netgear R6300V2) | 6.6 2025-08-03 | colinrk | ||
| Firewalla Purple | rik | |||
| FRITZ!Box 6591 Cable (Vodafone) | juhl | |||
| FRITZ!Box 7590 | Geert | |||
| Fritz!box7530AX | 6.8 | |||
| GL-iNet GL-AC1200 travel wifi router | cloudscapes | |||
| GL-iNet GL-ARM300 (shadow) wifi router | cloudscapes | |||
| GL-iNet GL-AX1800 Flint | blaster, Mikejc55 | |||
| GL-iNet GL-B3000 /Marble AX3000 | Mattbeensick | |||
| GL-iNet GL-MiFi | 6.6 2025-08-11 | rik | ||
| GL-iNet GL-MT3000 Beryl AX | bqyoung | |||
| GL-SFT1200 | 6.8 | |||
| GLi-Net GL-X3000NR | 6.8 | |||
| Google Home AP | Not sure what protocols tried | triplef | ||
| HELIX | triplef | |||
| Huawei B525s-65a | WPA/2: |
Si1208 | ||
| Huawei Echolife HG8245Q | Paul | |||
| Lifebox 5 | 6.9 | |||
| Linksys EA6900 | moonsong | |||
| Linksys EA6900 | Mikejc55 | |||
| Linksys Velop MX55EC | guardian241 | |||
| Linksys WRT3200ACM | Icondog | |||
| MikroTik RouterBOARD cAP 2nD (with stock RouterOS v6.42.12) | 6.6 2025-08-11 | rik | ||
| MikroTik RB951G-2HND and RBcAPGi-5acD2nD-US | triplef | |||
| MikroTik RBcAPGi-5acD2nD | Haley | |||
| MikroTik Router/Switch CRS109-8G-1S-2HnD-IN | bpaddock | |||
| MikroTik RouterBOARD 962UiGS-5HacT2HnT with OpenWRT | rik | |||
| Motorola DOCSIS 3.1 Cable Gateway MG8702 | whatever | |||
| Netgear 6700 v3 | Ironman | |||
| Netgear AC 750 Wifi Range Extender Model EX 3700 | Diode | |||
| Netgear AC1750 Smart Router | Not sure which protocols tried | TheBeeg | ||
| Netgear AC1900 Smart WiFi Router, Model R7000 (Max: c7000v2) | WPA/2 | 2025-08-11 | Inframan, Max | |
| Netgear EA6200 | moonsong | |||
| Netgear N600 | Mattbeensick | |||
| Netgear Nighthawk 7300 | MacG | |||
| Netgear Nighthawk AC1900 - R6900 | WhiskeyColorado | |||
| Netgear Nighthawk M1 | raggadaz | |||
| Netgear Nighthawk R7900P | Kevin | |||
| Netgear Nighthawk X65 AC3600 R7960P | baruk | |||
| Netgear R6400v2 | Higgins1010 | |||
| Netgear WNDR4500 | PeterK | |||
| Nokia E-240W-A | dobby | |||
| Orange Livebox Fibre G06.R04.C06_10 | ProxyGeek | |||
| Pace PLC 5031NN-030 | :red_circle | 2.4GHz only A/P | Fabian77 | |
| Sagemcom / F@st 5655v2 AC RF | brinerustle | |||
| Sagemcom BT Hub2 (UK) GRV9517UAC34-asa | superwizard | |||
| Sagemcom F@st 5366s | dwilson | |||
| Sagemcom F@st 5370e | Rempo | |||
| Sagemcom F@st 5670 | brinerustle | |||
| SFR box NB6VAC-FXC-r2 | Vrovig | |||
| Smart RG SR516ac | All variations tried | 6.6 | blulight | |
| Technicolor TG389ac | 6.9 | |||
| TP Link AC1900 Archer C80 | Nefer | |||
| TP Link DECO XE75 | 6.9 | |||
| TP-Link AC1900 Archer C9 Ver 2.0 | 6.6 2025-08-11 | Nefer | ||
| TP-Link Archer A20 v1.0, 1.1.4 Build 20231011 rel.36819(5553) | 6.6 2025-08-11 | Morogan, Nefer, Foundit | ||
| TP-Link C5400 | 2.4/5GHz, TKIP, AES, b/g/n, n only | tesladude | ||
| TP-Link Deco X55 Pro AX3000 | bejinxed, Max | |||
| TP-Link Deco X75 Pro | jcaceres | |||
| TP-Link EAP245 | 6.6 2025-08-11 | rik | ||
| TP-Link TL-WR840N | jojumaxx | |||
| TP-Link TL-WR940N | dpourkesali | |||
| Ubiquiti Unifi (various models AC Pro, UDM Pro, UDM Max models etc.) | mike8itall, xancudo, ChinPerfe | |||
| ZTE LTE Ufi, model mf871rs2 | Enduro | |||
| Zyxel C3000Z | SolderingIron | |||
| Asus RT-BE82U | WPA3 | 6.9 |
