No sound on calls Brax 3
I’m having an issue with no sound when calls are answered. Neither party can hear the other although the call is connected. I found a similar thread with no resolutuon.
Sim card is Mint. The card works in my Samsung phone, and a USCellular card (also TMo) works in the Brax3. I also received a call from Mint when setting up the card. APN looks ok. Phone has permissions. Any thoughts? Please explain like I’m 4 as my phone tech knowledge is extremely limited. Thanks.
Reboot the phone and try some other phone apps from F-droid , someone had a similar problem with the speaker and it was fixed for the native app after using another app.
Downloading a different phone app worked. Thanks!
Which app did you download ?
Fossify phone.
Here are some extra words to make the post long enough. :grin:
Thank you, just searched fdroid and couldn’t figure out which would work.
Note: I did see the Fossify offering and currently use their calendar and messages so was a bit concerned about creating another “monopoly “. Any concerns there?
Monopoly for something open means that it’s a good product but anyway you can spin-off it anytime like with Firefox.
Good choice! (IMO) :wink:
On related note if you are new to BraX3 see also my thread here that might help with suggested apps to get started with if you haven’t already:
I can especially recommend using most of the Fossify suite - Phone, Messenger, Contacts, Files & Gallery (Camera not so much).
(I primarily use the Fossify Files app, rather than the default Files app included in iodéOS):
Also if you ever have issues saving attachments from messages, etc, see this thread:
P.S. Recommend the Save Locally app as a secondary solution if you ever have issues long term with saving attachments.
