Updated Brax 3 from 6 to 7, ended up with Android 16
Just helped my girlfriend finally set up her Brax 3. We had the normal “can’t update from 6.3” issue. Had to manually open a GIT link and download an update to the Updater. Very long download. Installed and rebooted. Was supposed to update to Iode OS 7.1
Since it was only supposed to update to 7.1, I wanted to update again and catch up to my phone at 7.8. When I went to Updater, it shows operating system as Android 16.
When I went to System Settings>About Phone, it shows Android version as 16. Below that it shows iode OS version as 7.2-20260131-brax3
I have no idea why there is an Android version (didn’t realize this). How do I updater her phone to iodeOS version 7.8-20260930-brax3 which is on my phone? Updater says: “No new updates found. To manually check for new updates, use the Refresh button.” The Refresh button doesn’t change anything. How can I update her iode OS?
Thanks.
Hi there.
The OS on BraX3 is Android based. It uses the open-sourced layer of Android, stripped of any proprietary google software. iodeOS 6.x series was Android 15 based, while the 7.x series is Android 16 based.
Since version 7.3, we moved OS updates from iodé’s servers to our own, so phones on 7.2 need a one-time fix:
  1. Long-press the Updater app → App info.
  2. Tap ⋮ (top right) → Uninstall updates.
  3. Open the Updater again and refresh. 7.3 will appear. Install it.
The above is from our FAQ & Troubleshooting article
Once you follow the above and update, the device can fetch future OTA updates via the updater.
Thank you very much. Very helpful!
