I’ve had a look around the forum, but can’t really find what I’m after.Finally got my Brax3 and charged it up. Went through the set up video, Rob put up. I cant get the phone to connect to the WiFi. Did a factory reset, but thats about all I was prepared to try. Connects to mobile network no issue. Its running version 6.3 so tried the updater, it couldn’t find any updates?.
I’m on Australia, both mobile and WiFi are on Telstra.
Its a known bug on 6.3 so updating it to 7.0 will fix it. The other current anomaly is the updater also needs updating, just to get the current update to 7.0. And once updated, the updater needs to be put back how it was. Sounds worse than it is
I tried linking to the thread regarding the steps but it wouldn’t stick for some reason (my incompetence being the likely cause).
I was hoping I could find another way, as I’m scared of rendering it inoperable. It doesn’t seem so daunting after a sleep! Oh well, better test the water, as it needs to happen.
