Brax3 NOT connecting WiFi
I’ve tried all the workarounds - those do not work.
My router (CenturyLink) Zyxel C3000z
I’m told:
CenturyLink Zyxel C3000Z is a combo DSL modem + Wi-Fi router, sometimes called a gateway
Hi @bcSteve and welcome to the forum. You are probably best to post this in the actual (official) wi-fi issues thread, not as a new thread. Perhaps @plamen can move it there for you. Have you checked if your router is in the list there?
Also I know you have said you have tried all the work arounds so you are likely going to have to wait for the fix. See the existing threads on this. LineageOS are currently working on it and it will get passed to iodéOS once they figure it out…
The official BraX3 one:
Also these may be of interest if you gavent looked at them previously - unfortunately many of them do duplicate some info, but hopefully you will find things to check or try thatbyou haven’t yet; and/or identify for sure if your router is one of the ones affected that the phone and it won’t play nicely together…
Wifi authentication issues solved in latest beta, it should hopefully solve the issue for you.
It will also come as a “stable OTA” update in the near future as well.
